mytthor's avatar
mytthor
Water heater not working
Posted: 06/02/13 06:59pm Link | Quote | Edit | Print | Notify Moderator
I have a 2006 Jayco Greyhawk. Both the electric and propane functions for the water heater have stopped working. I am on the road. They worked last night but will not work today. I have checked the breaker and it is not tripped. Does anyone have any suggestion or could anyone recommend a repair shop near St George UT.
  • If you have an electrical multimeter, check to see if you have 12 volts going to the control board. With both propane and electric not working, that is where I would start. Check to make sure the connections are clean and tight on the wires going to the circuit board.
  • No gas? Fuse blown, bad control board. Without checking it there is no way to tell you for sure.
