dougrainer
Nov 09, 2017Nomad
It is the BLACK that is switched and if the ON/OFF is stuck ON, odds are the switch is melted. Yes, the Black goes thru that switch. Make sure you get a Suburban replacement switch, as most switches you will find aftermarket will not be rated for the AMPS going thru the switch. Doug
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
