j-d
Nov 09, 2017Explorer II
Sounds like your WH might be same as ours, Suburban SW6DE. Amazon has the "Suburban 232259 Electrical Element Switch - SW Series." Just looked at a heater yesterday where the switch no longer moves. Ours probably doesn't either, but we have an inside wall switch.
Ours wasn't heating on electric, and I was sure it was the Element. I'm usually a better troubleshooter than this, but I MISSED the open connection in the punch-down splice box in the cabinet, at the rear (inboard) end of the water heater. Suburban puts the heater's connection box where it falls right at the inside wall of the coach body. Jayco ran a short wire from there, to a punch box fastened to the kitchen floor. One of its connections had burnt out. In my case, it was the White/Neutral wire, so I was finding voltage all the way to, and across, the Element. ACROSS should have been my clue. Hot TO it, OK. Hot Across it, Bad. Circuit wasn't complete back to the Neutral side of the Breaker panel.
A new Box, punched down carefully, probably would have been an OK fix. Having Wire Nuts, I simply gutted the Box, cut out the plastic that supported the connections, and used it as a Splice Box for Wire Nut connections. I twisted the solid copper wires together with pliers before putting the wire nuts on, and also wrapped the nuts to the wiring with electrical tape.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
