donn0128
Nov 09, 2017Explorer II
Dick_B wrote:
I had to replace the switch and found some wires melted. Repaired everything but had to remove the WH to do it. Also found we would blow a C/B if we were heating water with electric and had another current hog, like a coffee pot, on at the same time.
So now I heat on propane and keep the electric as a backup.
Bad switch, melted wires all too common. Replaced my 12 year old Suburban last summer for the same problems. Switch frozen, bypass the pesky thing. Melted wires, replaced them. Failed for the third time and got fed up. New water heater from best converters was pretty cheap, so out with the old, in with the new took me only about a hour.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
