shastagary
Nov 09, 2017Explorer
taking things apart to check voltage at the tank switch would be a real major pain anywaythe switch can be pried out from the outside with a screw driver make sure the breaker is turned off first i had to replace mine this spring it is not hard to replace and does not cost much.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
