wrgrs50s
Nov 09, 2017Explorer
Do as shastagary described. If the switch is stuck you can guarantee its melted inside and that is where your voltage issue is. Once you've done it you'll see how easy it really is. A bent screw driver can even make it easier to get under the outside lip of the switch. The ends of the switch are spaded and it's just an unplug the old and plug on the new and stick it back in the slot.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
