Gjac wrote:
SCVJeff wrote:
The problem is not waiting, it's the actual ground bond between the thermocouple/ starter, burner assy.. Any even slight corrosion under those brackets will cause it to do exactly what you see. This happened to me several years ago and I ended up buying a replacement control board before figuring this out. I cleaned everything and added star washers to all screws just to make sure the ground return was solid.
Are you talking about the steel bracket that holds flame sensor and where it mounts to the burner assy?
yes. The return for the sensor is through the bracket itself. At least it is on mine
