Gjac
Jul 16, 2014Explorer III
Water heater problem made worse
My 6 gal Atwood G6A-8E HW would not stay lit,it would light and stay clicking then shut off. I replaced the flame sensor last year so I decided to clean the electrical contacts orifice and flame sensor tips but still could not get it to stay lit. I then started to clean the grounds and noticed the ground wire for the two green wires on the gas valve was rusted so stared to remove nut to clean terminals and pulled one of the green wires out. Has anyone done this before and have re-soldered the wire back or do I need a complete new gas valve? Hopefully the picture comes attached.
Hpefully a picture will come this time. It is a wire that just broke no spade connection. I figured I would solder back together to continue to trouble shoot system If this doesn't work the only thing left is the control board which I will test next. The ground is the left hand nut when I went to take it off it pulled the wire out. The terminals and nut were rusty. Lesson learned is remove the gas valve first if nut and terminals are rusted together.
