scmajm's avatar
scmajm
Water heater problem
I went to use my hot water this weekend and nothing came out of hot side, turned faucet on and nothing came out, water tank is full, anyone have any thoughts?
  • If your water heater was empty it will take a while to fill it before water starts coming out.
    Just a thought !!
  • All the valves are in the proper position, any chance water heater could be clogged?
  • Did you have cold water, but not hot water? Meaning, the cold faucet ran water, and the hot faucet did not run any water at all? If so.... check the water heater winter by-pass valves. If you have more than 1 valve, chances are, you have water turned off going into the tank and water beyond the outlet side. It's entirely possible to kill all hot water flow if you'rs has the 3 valve system.
Having RV issues? Connect with others who have been in your shoes.24,211 PostsLatest Activity: Mar 09, 2025
