therink wrote:
The electric element for you water heater doesnt have a fuse on your panel, it has a dedicated 15 or 20 amp circuit breaker on the 110 volt panel. The fuses you are referring to are for 12 volt.
Except Atwood uses a 12V DC (fused) circuit to the ON/OFF switch then to a relay to activate the 120V AC to the element.
No 12V DC....no 120V AC to element.
Ex-Tech wrote:
BTW, that inside warning/check light is only for gas operation.
On Atwood the 'fault' light will come on with electric IF the ECO (high temp t-stat) OPENS
