I need to remove the 10 gal water heater from our Allegro Bus - a welded joint on the tank let loose. Anybody here have experience removing one of these? Tips? Thanks!
The fittings the water lines attach to are welded to the tank as the tanks are too thin for threads. Access is from both sides (in and out) plumbing wires and gas lines need removed. Use your smart phone and take lots of pics to help reassemble. Good Luck, Mike
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jan 16, 2025
