Water SWELLS when heated
By design water heaters have a void at top of tank above hot out for an air pocket.
Air pocket is normally established upon initial filling of WH tank...bleed air out of system via a open faucet.
Over time Air pocket can get lost or absorbed into water.
W/O air pocket to control increase in pressure from water swelling the T&P Relief can 'weep' as water is heated (can't compress water----can compress air)
As noted above re-establish air pocket (due to small size of RV water heaters air pocket needed)
