Old-Biscuit
May 02, 2016Explorer III
Nothing looks modified on that WH.
That sheet metal is the exhaust vent diffuser
Your issue is improper air/fuel ratio mixture.
You need to remove burner tube and clean it out with small bottle brush, then run a wire thru combustion chamber an dout exhaust vent....tie a rag to wire then pull it back thru to swab out combustion/exhaust 'U' tube.
Also remove main orifice (brass insert) that is screwed into gas valve and clean out the center hole (soak in alcohol and blow out with air)
Then reassemble........ fire off propane flame and adjust 'air shutter' until main flame has nice BLUE flame (Orange and loud equals soot)
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
