opnspaces
May 04, 2016Navigator III
Sounds like you have a spiderweb in your burner. As Old-Biscuit says take it apart and clean it out then reassemble. They really are pretty simple to work on. One caution. when you clean out the brass propane orifice, just do as Old-Biscuit says, soak and blow out with air.Do not run any wire through the orifice as it is a carefully calibrated opening.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
