dougrainer
Mar 10, 2016Nomad
Casinojunkie wrote:
Update!!!
Did a test this morning and found water temp after heater running for 1 hour on electric was 135* using a meat thermometer. Water heater did not shut off the entire time, checking with a "Prime products A.C. Voltage tester"
Maybe my getting old is more sensitive to my skin.
Do not know what steps to take now.
Thanks for all responses.
You stated your test was on 120 electric and water heater never shut off. You used A Prime products tester. Unless you were using a AMP meter, how could you possibly know the 120 did not shut off? Where was your prime products tester connected????? 135 degrees is right where it should be. Can you please post the MODEL NUMBER of the water heater? Doug
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
