jjrbus's avatar
jjrbus
Water heater temperature
Too hot outside, so time on my hands to mull things over.
I find RV shower to be a pain. Trying to get the temperature right, wasting water on a limited supply, the dripping of the RV type shower head. If you know what I mean, you know what I mean.
Seems like a practical answer is a warm water tank, one that heats water to a reasonable temperature. Any such thing?
  • Regulation would be perfect!
    Thats what I was thinking, replacing the limit/temperature switches. But above my paygrade.
    Did some looking around and 98 to 104 is the recommended temperature for showers by doctors, dermatologists etc. I believe the heaters are set at 130 degrees.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    Tank temp is regulated usuallyu 120 degrees. You can get a higher temp t-stat for most makes.
    The "Dripping shower head" if you use a shower head with a cut off and totaly cut it off then when you restore flow you tend to regret it (Too cold or too hot) but the DRIP tends to make is "normal" when you re-start flow (This is assuming a cut off valve in the shower line not the mixer valves)
    There is also a temp, regulating mixer valve or several out there but I do not have a link.
  • It's been a long time, but I think I changed one once to a lower temperature setting. Removed and put in a different thermostat.
Having RV issues? Connect with others who have been in your shoes.24,189 PostsLatest Activity: Jan 21, 2025
