hhornig
Apr 28, 2015Explorer
Chris Bryant wrote:
If that is on the front (outside) of the tank, it should have a piece of foam insulation covering it and the ECO. There should also be a large washer (metal on older ones, clear plastic on newer) between the spring and metal tabs- the washer has a cutout on it to slip under the tabs while rotating.
IOW- if everything is installed correctly, there shouldn't be a problem. Worst case- buy a new thermostat/eco assembly- under $20.
Thanks Chris, I went to a local dealer and found a new assembly for $15.00. The plastic washers were missing on the original unit. Some one probably removed them and lost them. The spring will hold under the tabs if the circumference is expanded, but it will eventually work out as it happened.
