wa8yxm
Oct 18, 2017Explorer III
How does he put the cover back on..
Simple. after draining the tank he removes the pipe (I lay mine on the bottom of the compartment, or rather I did when before mod) and puts the nylon plug or anode rod back in.. You only screw in the pipe while draining the waterheater
Oh you want it COLD not hot, and screw it in quickly.. You may get some water inside, but only a small amount.
Another option would be a half pipe.. try 2" sawed in half under the outlet while you screw in the extension.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
