wa8yxm
Apr 10, 2023Explorer III
The instruction manual says it has 120 volt connections.
These are GENERALLY on the other side of the water hater (not the side pictured) where the pipes connect.
On that water heater you have a propane system which has everything pictured
And a totaly indpendent electrical system.. Though I'm not sure if that's optional or not..
But somewhere there is a switch to turn it on.. if you have it (need not be anywhere near the water heater) Look on the other side for the wires if they are there.
If not.. Hot Rod (Or HottRod) from any Decent RG store. It Screws into the fitting the anode is currently screwed into.. Its not as hith wattage as the standard heater element but it works very well.
Having RV issues? Connect with others who have been in your shoes.24,404 PostsLatest Activity: Aug 07, 2026
