went to fire up the water heater over the weekend (testing all systems)- The electric rod that heats the water kicked in fine- I went to turn on the gas (which usually heats faster) and nothing- I kn...
I been in the same situation. If I recall correctly, should the water in the tank be already hot - the gas option will not/or may not start. Once the water is cool/cold and the electric option is shut down - it should be fine. Good luck.
