went to fire up the water heater over the weekend (testing all systems)- The electric rod that heats the water kicked in fine- I went to turn on the gas (which usually heats faster) and nothing- I kn...
Does the WH make a snapping sound when you try to start it? If not you might not have 12 volts to the ignighter. Also check for bug nest and spider webs in the gas burner. Just things I have had happen with mine. Chuck
