JimVanExplorerOct 13, 2014Water heaterMy new unit has a two way water heater, to use it on electric I have to go to the outside access door and turn on the switch. Can I just leave this switch in the on position and leave it there.
jtelExplorerOct 13, 2014Yes, just make sure you have water in the tank if not when you plug in to an outlet or run generator it will send power to the element and burn it out
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,209 PostsLatest Activity: Feb 24, 2025
