JimVanExplorerOct 13, 2014Water heaterMy new unit has a two way water heater, to use it on electric I have to go to the outside access door and turn on the switch. Can I just leave this switch in the on position and leave it there.
MFLNomad IIOct 13, 2014Yes you can, as long as you always have water heater full of water.If you drain the WH, be very sure the switch is off first, or you will burn out the element.Jerry
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,209 PostsLatest Activity: Feb 24, 2025
