My new unit has a two way water heater, to use it on electric I have to go to the outside access door and turn on the switch. Can I just leave this switch in the on position and leave it there.
Yes you can. Unless you drain the water heater tank. IF you ever drain the WH, you will need to turn off the electric switch, or it will burn out the element unless you fill it again before you plug the RV into shore power.
Having RV issues? Connect with others who have been in your shoes.24,209 PostsLatest Activity: Feb 24, 2025
