AlexhunterExplorerMay 01, 2017Water heaterMy water heater will not run on 120v power or propane gas. Has anyone encountered this issue. Thanks. Rick
11 RepliesReplies sorted by NewestShow MorecorvettekentExplorerMay 01, 2017Check to see if you have 12 volt power to the control panel.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
Related ContentAtwood water heater problemWater Heater Replacement RecommendationsWater Heater Leak on start up.Suburban SW12DEL Water Heater On/OFF switch melts???Tankless water heater
