RGar974417
May 04, 2018Explorer
Water heater
We have a Suburban water heater. It worked fine for the first 2 years. This time out,as soon as I hit the switch,it goes to DSI fault.I tried the reset but that didn't work. Gas supply is fine. Any su...
donn0128 wrote:Yes to all of them. It works on 120volts but not on gas. When I got the sweitch inside the teailer,it shows DSI fault immediately. I was thinking the control board too.
Suburban did have some control boards that failed.
As some trouble shooting,
Did you press the reset buttons for both 12VDC and 120VAC?
Have you confirmed you have 120VAC
Have you confirmed you have 120VAC past the crappy outside switch?
Have you confirmed you have the tank full of water?
