RGar974417ExplorerMay 04, 2018Water heaterWe have a Suburban water heater. It worked fine for the first 2 years. This time out,as soon as I hit the switch,it goes to DSI fault.I tried the reset but that didn't work. Gas supply is fine. Any su...Show More
donn0128Explorer IIMay 04, 2018You probably have one of the bad controllers. Have you checked for volts at the board input?
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 09, 2026
Related ContentAtwood water heater problemWater Heater Replacement RecommendationsWater Heater Leak on start up.Suburban SW12DEL Water Heater On/OFF switch melts???Tankless water heater
