cpaulsen
Dec 23, 2019Explorer
water heater
Sububran water will not ignite when on propane....electric portion works fine.....and yes...I do have propane
cpaulsen wrote:
For propane....it does not even attempt to light....no clicks!!! Checked all connections and still nothing. No red light comes for the switch ib the control panel. What a pain to get to the control board....take panel off inside the basement....wiggle your way in behind the furnace to get to the back of the water heater....geez.......what a design that is!!
cpaulsen wrote:
All up and running
BFL13 wrote:cpaulsen wrote:
All up and running
It would help us all if you explained what got it going. Thanks.
cpaulsen wrote:
What happened was....I had the electric portion on....and the water was to hot to make the propane fire up. Run the waterthru the taps till I used a lot of hot water which then got cool enough to let the propane fire up. Dumb me!!!
