wnjj
Feb 28, 2018Explorer II
Yep. Water pump shouldn’t allow backflow, but is. The fix can be as cheap as taking it apart to clean it or even just using the pump. Worst case is a new pump.
Others with the same issue. Both cleared up by using the pump:
https://www.rv.net/forum/index.cfm/fuseaction/thread/tid/29566376
https://www.rv.net/forum/index.cfm/fuseaction/thread/tid/29569488
I assume you are referring to the fresh water tank. Holding tanks are typically the gray/black waste.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 17, 2026
