MrWizard
Feb 28, 2018Moderator
bypas or no bypass
the water should not being going pass the toilet valve or water taps
what is filling up the black tank, or both black and grey
the toilet valve is weak and/or you have way to much water pressure
do you have a water pressure regulator on the shore hose/fill ?
you should have one when connected to city water
check valve in the water pump stops back fill to the fresh water tank
it has nothing to do with the 'holding tanks'
so what are you saying, what is happening ?
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 17, 2026
