Dutch_12078
Mar 02, 2018Explorer III
The check valve in the pump is the issue, and if disassembly and cleaning it doesn't fix it, then the quick low cost fix is to add an external check valve on the output side of the pump. Most hardware and home improvement stores will have one that will work.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 17, 2026
