RLS7201
Mar 02, 2018Explorer II
wnjj wrote:RLS7201 wrote:
So much nonsense about check valves in water pumps. There are NO check valves in water pumps. There are inlet valves and outlet valves. Both an inlet valve and an outlet valve would have to fail for water back flow to the fresh water tank.
Richard
The definition of a check valve: "a valve that closes to prevent backward flow of liquid."
Those inlet and outlet valves you refer to are check valves.
You're right that both the inlet and outlet (check) valves need to fail or get debris in them for water to backflow but it seems to happen often enough as evidenced by the people whose issue goes away by simply using the pump.
And in your definition, you defined ONE valve, which is a check valve. In pumps the valves are inlet & outlet valves, not check valves. Some one on the internet misdefined inlet & outlet valves and it caught on. Would you define the valves in an internal combustion engine as check valves?
Richard
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 17, 2026
