Sjm9911
Apr 17, 2022Explorer
If you cant get it off by soaking or using some sort of penetrating oil. You can try a key hole saw with a metal blade or a mini hacksaw. Cut the male end , lengthwise, in like 3 spots. You will cut into the threads on the female end a little, but dont cut through the whole fitting. After you make the cuts, pull off the stuck fitting. The small cuts in the thread will not stop you from using it. If all else fails, replace the whole thing. I have problems at home with dissimmiler metals and leaving my hoses attached the the home for half the year. I spray the ends with silicone spray now.
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
