carjockie's avatar
carjockie
water leaking on rear slide
I have a 2011 Coachman Mirada with 2 slides, when it rains i get a lot of water coming in on the rear slide. Has anyone have the same problem and what did you do to correct this problem.
  • donn0128 wrote:
    Slide seals damaged. Are you level? Do you have slide toppers?
    This.
    Also, put the slide out at night, turn off all interior lights and have someone go outside with a flashlight and slowly shine it around the slide seals....you should be able to find the leak.
  • WHERE on the slide is water leaking? Knowing where will generate more suggestions.
  • Slide seals damaged. Are you level? Do you have slide toppers?
