sandeeAR wrote:
Water will not flow into the RV. We have check water bib, hose is not frozen (just filled tank with the hose). Took apart fitting entering RV, no blockage. Pump is off. We are baffled. Any ideas? Of course it's Saturday night and RV repair closed until Monday. 25' Tioga Ranger. Btw it had frozen at the faucet 2 days earlier, so water flow for 2 days. All is thawed now and faucet repaired.
are you using one of those inexpensive in-line water "pressure-regulators"? they can become clogged with grit. if you're using one take it out of the line and see if that corrects the problem.
