agesilaus
Mar 13, 2019Explorer III
Then it's not the faucet. Generally you can just clean the wire mesh filter on the end of the spout to restore flow. Are you sure the water pressure into the RV is good? A kinked line, or a plugged water filter are other possibilities. Are you using the water pump?
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
