Loren_Ross
Aug 27, 2013Explorer
eHoefler wrote:
Check the vent pipe into the grey tank. If it is slid into a rubber collar at the top of the tank, slide it up and see how far it goes into the tank. My bet it has slid all the way to the bottom and is sealed off and not letting it breath.
I have absolutely no way to get to the top of the gray tank, unless I completely remove it from underneath. I also have no access to any of the piping as they are installed inside the walls. The only way to get to them is to remove the interior walls, and I'm not prepared to try that one. You may be right, but I have no way to determine that one.
LR
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
