Nicodemus's avatar
Nicodemus
Water pressure problem
We have a Prime Time Spartan. The water at the kitchen sink is a dribble, and the water flow at the bathroom sink is only slightly better. However, the shower has great pressure. I can't figure out why this is so or how to correct it. We use a regulator because the manager said that the pressure is high. Any ideas?
  • I wish I knew the answer or how to correct this problem. I have the same problem and yes I have cleaned the screens and have replaced the screens and cleaned out the washers in the valves. nothing has worked. the answers you got above are just the tip of the iceberg, just the start of going mad trying to figure this out. I'm beginning to think it is an engineering design
  • Check the strainer on the water pump if you are using water from the fresh water tank.
  • Are there water filters on the lines feeding these 2 sinks? Our galley sink has one, but I don't think the bath one does. Aerators (clean/replace) are a good place to start.
  • Bobbo's avatar
    Bobbo
    Explorer III
    Agreed. I have to clean my faucet screens every couple of years. I try to remember to do it every year when I de-winterize just to prevent the problem in the first place.
  • Have you checked and cleaned the aerator screen at the end of the faucet? You might also want to check to see if you have any type of screens on the water connection to your coach.
Having RV issues? Connect with others who have been in your shoes.24,326 PostsLatest Activity: Oct 23, 2025
