john_b1
Dec 30, 2013Explorer
hohiso wrote:Old-Biscuit wrote:skipnchar wrote:OP wrote:
Finally bought a 'real' pressure regulator that has a gage and is adjustable.
Hard to imagine why anyone would want to reduce pressure to less than maximum their RV is designed to handle. INCREASING pressure above that level when source is low pressure won't increase water pressure at all so not sure what the adjustment would do for you.
Mainly because the 'fixed' pressure regulator are set at 45#
With an adjustable one you can choose what pressure set point you want to use......30, 45, 50, 55, 60..whatever you are comfortable with.
And with an adjustable regulator......chances are it is re-buildable if needed
Also, I have been told by someone who knows that the typical cheap in-line regulator restricts flow as well as reducing pressure.
I personally have always called the cheapies a water reducer,never a regulator..jb
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 20, 2026
