a64armt
Nov 02, 2020Explorer
dougrainer wrote:
NEVER use more than 1 pressure regulator at a time. Adding an extra will indeed diminish flow and pressure. I have a hook up at work to demonstrate this. I connect a standard in line RV regulator to the end of the shop hose(shop about 65 psi). I then add the 2nd and then 3rd Regulator and the customer sees that the volume pressure is almost none. MY preference is to have the Water Regulator(adjustable) at the CG faucet to help protect my potable feed hose from the sun and excess pressure. Doug
I figured that was the case. I didn’t know the city water inlet was a pressure regulator as well until I had to replace it due to corrosion.
Makes sense and thank you for the info!
OJ
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 17, 2026
