Greetings All! My inline water filter canister broke at the threads. I replaced the canister and replaced the filter at the same time. Since the repairs, we have very, very little water pressure. I...
Can you bypass the filter? That would isolate if the problem is with the filter or somewhere else in the water system.
Also are you sure you bought the correct replacement canister? Just because it threads on does not mean it has the correct number and size of holes for proper flow.
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 06, 2026
