Don't know what happened but! I have an 2000 Avion. I just filled the water tank up. When I turn on the local water supply I have very little pressure and the water is coming out of the overflo...
My water control panel is in a side compartment with the controls for the waste, etc. It leaks when both city and RV pump is on.
I took then lines off the pump. The line that has water coming out from what I believe is the source has water. Shen I connect it up and remove what I believe is the feed line to the faucets there is hardly anything.
To stop the water from coming out the overflow drain I have to shut off the city water and pump.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
