lapdret
Apr 01, 2017Explorer
water problem
Don't know what happened but! I have an 2000 Avion. I just filled the water tank up. When I turn on the local water supply I have very little pressure and the water is coming out of the overflo...
lapdret wrote:
I took then lines off the pump. The line that has water coming out from what I believe is the source has water. Shen I connect it up and remove what I believe is the feed line to the faucets there is hardly anything
