I had low pressure in my 5er and removed the pressure regulator. The pressure increased and after about 4 hours I have only cold water in the kitchen faucet. I have lost all hot water and all water to...
+1 on the water heater check valve. If you can do it youself the replacement will cost you about $10. Have a look at it before you go to get the replacement as the thread setups can be different. It should be a male thread into the tank but the outside end can be either male or female thread depending on what you currently have. Any RV place should have them.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
