I had low pressure in my 5er and removed the pressure regulator. The pressure increased and after about 4 hours I have only cold water in the kitchen faucet. I have lost all hot water and all water to...
1. Do NOT remove the Water heater drain plug, not neccesary, just open the Pop Off valve and see if water flows 2. Do you have a Whole House filter???? If so, it may be clogged. remove the element and reinstall without the element and see if you have water. Doug
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
