PeteK-Hou's avatar
PeteK-Hou
Water Pump - open ended hose
I have a ShurFlo 4008 water pump. I'm trying to diagnose the 'pulsing' of the pump. I understand it may just be an adjustment of the pressure switch. It doesn't pulse if I open the kitchen Unfortunately, the 'business end'of the pump was mounted towards the outside wall, make the adjustment screw non accessible unless I remove the pump (at which time I might as well replace the pump with a better unit).
But, my real question is there are 2 lines into the pump, one from the fresh water tank (valve in open position) one that has the valve closed and is open ended, no fitting or anything. Is this for adding antifreeze to the system for winterizing?
Having RV issues? Connect with others who have been in your shoes.24,335 PostsLatest Activity: Nov 14, 2025
