Jay_Pat
Nov 28, 2018Explorer
DrewE wrote:
I would guess the water heater was not quite entirely full or at least had a larger air pocket than typical, making it act as an accumulator. If you have the bypass valves set up in a partially bypassed, partially not bypassed state (which may or may not be possible depending on how the valves are arranged), you can get a far more extreme version of this...which I will say did confound me once for awhile until I saw what I had done.
Last winter, I blew out the water lines to winterize.
This summer, I used only water hook ups.
I never used hot water when traveling/using the pump.
Just went out to the rv and turned on the hot water using the pump only.
Got a lot of air. Turned on other faucet and got more air.
When the air stopped, I tested the pump cycle and the cycle time is back to normal.
So, somewhere in the hot water lines was the "air accumulator".
I'm sure (I think), I opened the hot water faucets to fill the hot water heater last spring.
Thanks for all the responses!!!!!
Pat
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: Nov 08, 2021
