wa8yxm
Apr 21, 2020Explorer III
The #1 Suspect is the pump inlet strainer.. If you did not properly winterize this part it may be cracked. Then follow the inlet line all the way to the tank.. IN The tank there may be an "outlet Strainer" as well (is in mine.. 2 of 'em originally only one was in use).. it may be "Slimed".
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
