Gjac
Apr 23, 2020Explorer III
You have gotten a lot of good suggestions so far, if none of them fix your problem check the parting line in the housing itself especially if you see a slight amount of corrosion where the housing comes together. The rubber diaphragm acts as a seal. You can remove the bolts and clean the diaphragm itself. Also clean the parting flange itself on both sides or the housing, then reassemble torquing the bolts evenly. I had to use a silicone sealer to stop the air leak, but my pump was 22 years old.
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
