Pipeman
Jan 18, 2014Explorer
I used to use a 45 gallon barrel and now have a 50 gallon container(agriculture) that goes in the bed in front of the 5th wheel and fits under the tonneau cover when not towing.There is a tap installed on the bottom end of the container. I also have a 45 gallon collapsible container(from Camping World) and that goes behind the 5th wheel cross ways with a furniture blanket under it so it doesn't get damaged by whatever gets in the bed of the truck. We use it because we also camp off the grid a lot. I used to use my air compressor with the 45 gallon barrel to move the water from it to the 5er but now use a 12 volt pump. It works very well and is a lot faster than air pressure.I tried gravity feeding it but can't always get the tank higher than the fill. I had to rig up a double female, end hose to go from the container to the pump. My three kids also use a 12 volt pump to transfer water. They all have the collapsible containers. I found a plug http://www.princessauto.com/pal/en/Other/7-pin-Trailer-Plug/8462558.p that goes into the rear receptacle of the truck and I put plug ends onto the wiring of the pump and a cigarette lighter end which plugs into the receptacle of the truck. No more long extensions to get 12 volts.
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 05, 2026
